Sheet to Cycle Matrix
Copies a spreadsheet to the Cycle Matrix.
Please note that when using this command, your spreadsheet must match up with the columns in the Cycle Matrix. The command will not work properly if the incorrect data is copied to the incorrect column.
For a full list of what the columns of the Cycle Matrix represent, click here.
  • Spreadsheet - Spreadsheet to be copied. Set [c,r] to [1,1].
On Button Click Logic
Sheet to Cycle Matrix ss_CycleMatrixData[1,1]
