References List
The References button on the Visual Logic list opens up a list of Visual Logic routines or Simulation Objects that call the highlighted Visual Logic section.
The button is accessed through the Visual Logic list (All button on the the Visual Logic tab). Select a piece of code and then press the References button to open the list of references.
This feature is particularly useful when you are debugging and want to find where a Visual Logic section is called.
