Queue Properties
Read and Write Only Properties
The Queue properties that are editable through the Visual Logic Set Value editor are:
Sets the image used for the Queue to any image located in the Graphics, Images menu option.
Example:
Set Queue1.Image = "BlueB": where BlueB exists as an image.
Note the Inverted Commas around the name of the image.
Index
Sets the Index number of the Queue to a value other than the default value.
Example:
Set Queue1.Index = 5
Initial Contents
Sets the Start Up contents of the Queue.
Example:
Set Queue1.Initial Contents = 10: places 10 items into the Queue at the start of each run.
Max Size
Sets the Capacity of the Queue. Set this value to -1 when the Queue has an infinite capacity.
Example:
Set Queue1.Max Size = 10: sets the capacity of the Queue to 10.
Min Wait Time
Sets the Minimum Wait Time property.
Example:
Set Queue1.Min Wait Time = 5: each item will wait 5 minutes before being released from the Queue.
Name
Allows the name of the Queue to be changed or accessed.
Example:
Set Queue1.Name = "Change the Name": changes the name to whatever is inside the inverted commas. Set Var1 = Queue1.Name: sets a text Global Data Item to contain the name of the Queue.
Other Cost
This property can be utilised to add further cost details to your income statement.
Example:
Set Queue 1. Other Costs = 2000: sets an additional cost of 2000 to the Queue in the Finance Report.
Other Revenue
This property can be utilised to add revenue details to your income statement for a Queue.
Example:
Set Queue 1. Other Revenue = Queue 1.Count Contents*5: sets an additional revenue of 5 for every Work Item in the Queue at the time of execution to the Finance Report.
Shelf Life
Sets the Shelf Life of the Queue. Use this with an Expired Only Activity.
Example:
Set Queue1.Shelf Life = 5: sets the maximum amount of time each item can remain in the Queue.
Selected
Sets whether the Queue is selected onscreen or not.
1 = Selected
0 = Not selected
Set Queue1.Selected = 0
Results Collection Mode
Allows control over the collection of results for specific object through Visual Logic.
1 = Results Collection on
0 = Results Collection off
Example:
Set Queue 1.Results Collection Mode = 1
Travel and Contents
Returns the number of items currently in and on their way to the Queue. This include any item traveling on a transit link to the Queue and items currently in the Queue.
Example:
Set Var1 = Queue1.Travel and Contents.
Read Only Properties
Count Contents
Returns the number of Work Items currently located on the Queue.
Example:
Set Var1 = Queue1.Count Contents
In Count
Returns the number of incoming routes to the Queue.
Example:
Set Var1 = Queue1.In Count: Sets Var1 to the number routes that are connected to the Queue.
Out Count
Returns the number of Outgoing routes from the Queue.
Example:
Set Var1 = Queue.Out Count: Sets Var1 to the number routes that are connected from the Queue.
Unique ID
Gets Simul8's internal Unique Number that identifies every object - you can be sure it is different for all objects. It never changes once an object is in a simulation
