Copy Local Variables
The ability to copy local variables allows you to copy a section of Visual Logic that includes local variables, and paste it into a new or existing block which does not contain those variables.
When the lines of Visual Logic containing local variables are copied over, Simul8 will now automatically create them in the newly used section of Visual Logic. The data format is retained (ie, number, text) so you do not need to make any additional configurations once you have copied the logic over.
Local Variables that are copied still behave in the same way that they always have: they will still only exist in the section of Visual Logic that they are used/created in.
