Comments Dialog Box
Use this dialog to add documentation to your Visual Logic code.
In the Visual Logic Section Window (yellow screen) right-click or press INSERT to open the command menu. Select the Comment option.
A dialog with a text field will open. A memo can be written in here to describe what is happening in the code. When the OK button on the dialog is clicked, the memo will appear in the VL window. The comment appears in green text so that it can be distinguished easily from Visual Logic code.
