Update Component Toolbars
Refreshes buttons on toolbars when you have added or deleted component files.
None required.
Typically only needed if you are making an interface on top of Simul8. It is usually used after the zip component commands have been used to allow you users to make components made up of combinations of the components you have provided with your application.
