Sheet to File
Exports the contents of a Simul8 internal spreadsheet to a file. The file can be .txt, .csv, .rtf. This allows results or other data to be collected in Simul8 internal arrays and then exported to another application for analysis.
File name: File to read data from Global Data item sheet: Simul8 spreadsheet to import data to.
Examples
You can find a Simulation Example on the use of this command here: Sheet_to_file.s8
