Set Route Out Percent
When Routing Out Percent Discipline is used this changes the percentage of Work Items that are sent to a particular destination.
  • Leaving Object: Name of Object (could be either an Activity or Start Point)
  • Percent: Number between 0 - 100
  • Destination Object: Name of simulation object
Normally you will set several Route Out Percentages in sequence because the complete list of Route Out Percentages should equal to 100%. If you do not change several so that the total is 100%, Simul8 will automatically adjust these percentages for you.
Annotated Example
You can find the simulation used for this example here:
Set_Route_Out_Percent.s8
