Schedule Event On Work Item
Schedules a call to Visual Logic with Current Work Item, for example changing a Label value or an image.
- Visual Logic - Visual Logic code to call
- Time difference - Number of time units from NOW to when the VL Event will happen.
To see how this command can be used to change Work Items’ Label values, you can download this simulation file: ScheduleEventOnWorkItem.S8
The code is applied on Queue 2 On Entry and changes the Label value of all Work Items 5 minutes after they enter the Queue.
