Recorded Data to File
Writes to a nominated file the desired selection of results. Specify the path to the file inside the inverted commas, then specify the object and the result to be recorded. The file must be a text file.
- File name - Full path to file or just file name
- Simulation Object - Object's data to save
- Result Type - Class of recording
