Rebuild Chart
If a chart is set not to be updated automatically then when this command is called Simul8 will clear all previously plotted data points and redraw the chart.
- Chart: Name of the chart
See the Refresh Chart command to only redraw the chart from the previous point plotted. For optimal simulation speed use the Refresh Chart command rather than the Rebuild Chart command.
