Insert Into SQL Database
This command allows you to insert a record into a database.
To use this command you will need to know the table structure of the database.
Simul8 SQL Database: The name of the database where the record is to be inserted.
SQL Insert Command: SQL insert command syntax. This follows the format:
INSERT into XXX ('aaa','bbb') VALUES('yyy','zzzz')
where:
  • XXX is the name of the table in your database you wish to insert into the record
  • aaa and bbb are the name of the fields you wish to insert values into
  • yyy and zzz are the values you wish to insert into the fields. Note value yyy would be inserted into field aaa.
Suppose you have a db called myDB that contains a table called “Persons” that in turn has the simple structure below:
LastName FirstName Address City
Pettersen Kari Storgt 20 Stavanger
If you want to insert this record into the table
LastName: Hetland
FirstName: Camilla
Address: Hagabakka 24
City: Sandnes
Then you achieve this as follows:
Insert into SQL Database myDB, “INSERT INTO Persons VALUES('Hetland', 'Camilla', 'Hagabakka 24', 'Sandnes') ”
This will result in:
Hetland Camilla Hagabakka 24 Sandnes
Now suppose that you want to insert a partial record into the db
LastName: Rasmussen
Address: Storgt 67
Then you do this as follows \
Insert into SQL Database myDB, “INSERT INTO Persons (LastName, Address) VALUES ('Rasmussen', 'Storgt 67')”
This will now give you: LastName FirstName Address City
Rasmussen Storgt 67
As you can see from the second example the SQL query is very similar to the first. Since it was a partial record you wanted to add, you had to supply additional information to specify what fields in the record you wanted to fill.
