Get Contents Change
Returns change in contents (positive or negative) over a time period.
Simulation Object: a Tank
Start Time: start time of period to obtain result. Measured in elapsed simulation time since the start of the run
End Time: end time of period to obtain result. Measured in elapsed simulation time since the start of the run
Returned Change: Global Data Item that receives the percentage result.
Call at any time (but most likely used for reporting on End Run)
