Copy Selected Objects
Creates a copy of all selected Simulation Objects. This is useful for copying one or more Objects, when using Visual Logic. Please note that Objects need to be selected, either manually (by dragging the cursor over the Objects to be copied) or through Visual Logic (by using the Select Simulation Object command).
* X - Horizontal Offset: Distance measured from the left-hand side between the Object(s) being copied and new Object(s).
- Y- Vertical Offset: Distance measured from the top side between the Object(s) being copied and new Object(s).
*Quick Tip: You can estimate the distance by subtracting the Left and Top Coordinates of the New Object(s)’ location, from those of the Object(s) to be copied. The image below shows where these are available. You can also get Objects’ Location by using the Get Object Location command in Visual Logic.
Annotated Example
You can find the simulation file of this example here: Copy_Selected_Objects.s8
