Custom Views
Custom Views are ways of saving a one or more ways of setting up the visual display of a simulation. They automate the process of manipulating the screen to show certain aspects of your simulation.
Custom Views can be set up and saved, meaning that Sub-Process can be opened in certain views and closed in others, the zoom can be altered, and the scroll bars moved as you move from view to view.
To save a new Custom View, manipulate the screen to the view that you require then go to the Integrate tab > Custom Views > Save. You can give each Custom View a name and choose if you want the Zoom to adjust relative to the size of the screen.
To switch between different saved Custom Views, click on the Switch dropdown button int eh Views section of the Home tab.
You can also use the shortcut keys (CTRL + view number) to change the view, this shortcut can be used to change the view while the simulation is running.
Views can be amended or changed by selecting a view and manipulating the screen as desired then clicking the save button again.
