Current Work
The current work item in the context of the Excel Interface is the Work Item that has cause Simul8 to ask a question of VBA.
It is possible to change the current work item so that Excel/VB code can manipulate other work items. Changing the current work item so you can do this is perfectly safe - it will not alter the work item that has caused Simul8 to send a signal to your VBA macro.
