Snap to Angle
The Snap to Angle feature ensures that when altering the orientation of a Conveyor it will automatically snap to the closest set angle (set angles are 7.5 degrees apart, giving 48 set positions in a full circle).
To activate the Snap to Angle feature right click on the simulation window and select Grid > Conveyors > Snap to Angle.
This feature can be dynamically toggled by holding CTRL while re-orientating the Conveyor, allowing you to flexibly create Conveyor systems with both uniform or customized angles.
