Results Preferences
The following options can be customized from the Results tab in Preferences.
So that Simul8 can provide results graphs that are directly comparable results information is normally stored every 5 (default) simulated minutes for all simulation objects where graphing of results is relevant.
With simulations that run over a long time period you may want to increase this time interval (to save memory).
Parallel Processing
This enables Parallel Processing and lets you set the folder to be used to share files.
