Links Dialog
The links dialog lets you control routing arrows in large or complex simulations.
The dialog can be accessed through the Links tab.
To show the links into and out of any object click on the name of that object in the central “Object:” box.
To add (or remove) any of the selected object's routing arrows drag them from (to) the “Others:” box.
To hide the arrows exiting an object from the simulation window uncheck the “Display out links” check box when the particular object is highlighted in the “Objects:” box. This does not effect the routing of the simulation - it only hides the arrow from the display. (This is beneficial in the case of an object that has a large number of connections). Similarly, to hide the arrows entering an object uncheck the “Display in Links” check box.
