Attaching a Label
Labels can be used to route Work Items, to collect data and for a number of other purposes.
To enable a Work Item to be controlled by a Label's value or to be able to collect data in a Label, the Label must be added to the Work Item. Simul8 automatically adds a Label to the main Work Item type but if you have more that one Work Item type then you must add the Label to them.
To attach a Label to a Work Item type go to the Build tab > View by Type > Work Item Types.
Click the Add button in the Labels panel and select the Label you require. If the Label you require is not in the list presented click the New button and enter a name for your new Label.
