Go to End of Warm Up Period
Select this option to run your simulation forward to the end of the Warm Up Period with no animation. This is useful when you quickly want to get your simulation into a warm up state so you can then begin to run the simulation slower whilst you look at the animation to validate, verify your simulation or begin drawing insights from it.
You can access this feature from the Run drop down menu on the Home tab.
You can set the warm up time either from the Build tab on the ribbon or from the clock properties dialog.
