Pie Charts
Pie Charts are available to show the amount of time Activities have been working, waiting, blocked, in change over or broken down.
Open the Activity properties dialog and select the results option. To display the pie chart click the Pie Chart button.
To export the data that makes up the graph ensure the graph is displayed on screen. Then access the Chart properties through the Chart button on the Design tab. Select the chart of interest and click the Export Data button. The data that makes up the graph can now be pasted into another application such as Excel. Or right click on any open chart and select export data.
If a Trial has been run then the data displayed in the chart is from the last run of the trial.
Results are also provided in this format for Groups.
