Advanced Random Number Control
This dialog is accessed through the Advanced tab.
Its use is not normally required in building and running Simul8 simulations.
Changing the Random Number Stream Set number in the Random Sampling dialog is the best way to change the random number while analyzing simulations.
Use the advanced dialog if you want to change the random number stream used by an individual random sampling point inside the simulation.
Simul8 random number stream sets consist of an infinite number of individual random number streams. The advanced dialog lets you manipulate these streams.
The dialog lists all the places where random numbers are sampled inside your simulation. Click on one of these to display / change the seed used for the stream used at this place.
