Results - Examples
This section includes templates for obtaining standard results (including pre-embedded Simul8 results) or results in non-standard formats (including calculations of additional results and customised result logs).
- Display_Result_on_screen_during_Run.s8 Shows how to display a result dynamically updating on screen.
- Log_Entry_Exit_Times_and_Object_for_each_Work_Item.s8 Shows how to create a log for each Work Item entering or exiting a Simulation Object. The log records the Work Item’s ID number, the respective Object, and the entry/exit times to/from the Object.
- Get_Average_Confidence_Intervals_for_customised_results.s8 Shows how to get Confidence Interval Results for a result that you have created (i.e. could not be found in the list of pre-embedded Simul8 results).
- Track_time_each_item_spends_in_system_with_Visual_Logic.s8 Tracks time each Work item spends in the simulation. Please note that these results can also be obtained using Transaction logs by Area.
- End_Point_WorkCompleted_Results.s8 Shows how to display the Work Completed Result of End Points on a Chart.
- Timing_by_Label_and_Transaction_Logs.s8 This example uses Timing by Label, so that an Activity's process time depends on the type of the Work Item. Here, this is validated with the use of Transaction Logs.
