Select Work Item on Conveyor
Selects a Work Items as the current Work Item if it is the first Work Item found when searching a part of a Conveyor starting at “start” distance from the front of the Conveyor and ending at start+length. If there is not a Work Item at the region the current Work Item becomes zero.
  • Conveyor - Conveyor where the work item is currently located
  • Region Start - Distance from front of conveyor where search region starts
  • Region Length - Length of region that the work item may be found in
The “front” of a Conveyor is the point where the Work Items travel to while on the Conveyor. To select a Work Item that is ready to be removed from the Conveyor because it has traveled the full length of the Conveyor set the start and length parameters to zero.
Using Conveyors?
Check out our new Academy module, covering all things conveyors! Learn the functionality of conveyors at your own pace online with detailed video-based training modules and exercises, delivered by our simulation experts.
Learn more >
