Link Logic To Object
Connects a block of Visual Logic to an event trigger on a Simulation Object.
  • Visual Logic to use - The name of the visual logic section to be connected to the event
  • Simulation Object - An object that has an unused event that you need to connect to some logic to
  • Event - The event on the object that you need to connect to the logic
You can find a simulation example on this command here: Link_Logic_to_Objects.s8
