Create Shift
Creates a new Shift.
Shift - Name of the Shift (in quotation marks)
Creating Shifts can be created without the use of Visual Logic, through the Shifts Dialog on the Data & Rules Tab. Still, this command can be useful when a model is used for a wider range of occasions, where the number of Shifts and Shifts’ Properties are subject to change.
Annotated Example
In the following example, we have created a spreadsheet named ssWorkingHours. Create Shift is used here within a Loop Command to quickly create 10 Shifts, whose names are stored on the ssWorkingHours Spreadsheet.
