Compare Simulations
Whether you are working on a project with the rest of your team or you forgot which changes you made between different versions of your simulation model, you can use the Compare Simulations feature under the Advanced Tab to compare the current simulation with a saved version of the simulation.
Select Compare multiple simulations from the Advanced Tab and browse for the saved file that the open file is to be compared with. The files are displayed in XML format, with any differences highlighted in red.
Switch to the Summary to see the lines in the current simulation that differ from the saved version.
