Sets/changes a distribution you have defined.
Distribution Name - Name of the distribution (you have created) that is to be changed.
Distribution Type - The type of SIMUL8 distribution to be used.
Parameter 1 - The value of the first parameter for the chosen distribution type.
Parameter 2 - The value of the second parameter for the chosen distribution type (if used).
Parameter 3 - The value of the third parameter for the chosen distribution type (if used).
Parameter 4 - The value of the fourth parameter for the chosen distribution type (if used).
The sequence of the parameters for each distribution type in this command is always the same as the sequence in the interactive dialogs that set parameters of distributions. e.g. for a “Normal” distribution, Parameter 1 is the “Average” and Parameter 2 is the “Std Dev”
