Set VL Random Number Seed
Changes current seed for all VL based random numbers.
  • New Seed - The new seed value (Text Global recommended).
Experts only! We don't know why you would need to use this command because Simul8 does it for you when required.
It has same impact as changing the value in menu Trials/Random Sampling.
It changes the stream set number ready for the next reset to time zero. If used without reset will create results of dubious statistical purpose.
